3 members (Gray_Ghost, Wally / Montana, fonz8261), 161 guests, and 1 robot.
Topics128,192
Posts1,057,351
Members48,469
#128998 12/28/2004 2:15 PM
Ok guys "ol pops" is a little stymied here, started to hook up braided gas (SS) line to fitting to attach to gas tank. The fitting is a compression 8N 45 degree. The line is suppose to slide in but those dang gone SS fibers need trimmed. Tried everything in my shop (even a ginzoo pair of sissors) and can not cut clean.
Do not have a metal chopping saw problay borrow one from my work shop. Defiantly when I start installing SS brake lines? Any suggestions? Ben
popcorn The Truth is Out There (Yep I do pay attention)
#128999 12/28/2004 3:30 PM
I made some of those SS lines for my remote oil filter and the intake heat lines. I wrapped the
line with 2 turns of duct tape where I wanted to make the cut, then slowly cut it with a 32 point hack saw blade. Remove the tape and you have a very clean cut. grin Be careful though, those little SS strands will cut you in an instant. eek
#129000 12/28/2004 5:37 PM
I've used several wraps of masking tape and then a hacksaw. That stuff is a real pita. If you have any considerable amount of it to do (I did my whole 63 Nova from the fuel tank to the carb) your fingers are gonna bleed a lot.
#129001 12/29/2004 1:45 AM
On mine I wrapped it with duct tape and then used an air cut off tool. Works good.
#129002 12/29/2004 1:53 PM
Thanks Guys!!! Good ideas I have been thinking about getting a new (good) hacksaw. Also been thinking about getting the right cut off blade for my 4" grinder. I am to much of a perfectionist just want to make it look good.
popcorn The Truth is Out There (If you don't bleed a little bit the job isn't worth it) Ben
#129003 12/30/2004 3:56 PM
Junior Member
Junior Member
Here is one good artice. I remember another, but haven't come across it yet....
http://racingarticles.com/article_racing-28.html
