1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#128977 03/12/2004 11:40 PM
has anybody tried this on a 235 or any of the other stovebolt 6's? i was entertaining an idea of a custom system but wanted to know of any caveats? also does anybody know if i can use an aftermarket high psi mechanical pump mounted where the stocker is?
'59 Chevy 1-ton
'03 **** Lightning
'96 Kawasaki 1100 zxi
You mean like a blower? And by mechanical, I'm assuming you mean a Roots-type supercharger?
If so, I've seen a couple of them on the salt flats:
[img]http://www.chevyasylum.com/bsf2003/wf/031018/031018_060r8.jpg[/img]
This is a front-engine dragster with in inline 6 motor (I don't know exactly what motor it is) and a Whipple roots-type blower. It ran at the Bonneville Salt Flats last October. Their high speed was a little over 188.
by mechanical i mean a mechanical fuel pump. with a blow through carburetor system, i need a higher volume fuel pump capable of supplying fuel with pressure referenced with boost. this is easily accomplished with a mechanical pump, i just wanted to know where to get a high capacity mechanical fuel pump.
btw, sweet pic, but i wasn't planning on using a roots blower for the compressor, i have one of those on my daily driver, i had something else i mind for this.
'59 Chevy 1-ton
'03 **** Lightning
Why the focus on a mechanical pump? I would think you could find an electric one to meet your needs quite easily....or are you trying to make this a bit of a sleeper?
- Ryan
59 Apache Step
78 El Camino
http://www.wsu.edu/~rsain
sleeper, and cheaper. with the mechanical pump, it can easily be boost referenced. with an electric pump, i would need a boost referenced adjustable fuel pressure regulator. the elec. pump and regulator are expensive (read: a couple hundred bucks!) an mechanical pump is a lot cheaper.
'59 Chevy 1-ton
'03 **** Lightning
#128982 03/18/2004 12:57 AM
I have heard of people having problems with the #1 main bearing when running a blower on a stovebolt. You probably don't want to run too much tension on the harmonic balancer. Some people fabricate an external bearing.
I've been thinking about doing a turbocharger with fuel injection on my spare 235. A small turbo like a TO3 would work pretty well and you could use the stock exhaust manifold and a fabricated intake to make about 5-10 lbs boost at 2000 rpm. There are a lot of small turbos available because a lot of people with factory turbo cars like Eclipses swap them for bigger ones when they modify.
Paint & Body Shop moderator
The engine in the pic ChevyAsylum has posted is a GMC engine cool
yeah, i was planning on using a t3 or t4 turbo on my 235, so no tension issues. i have most of the system planned out. i am just trying to get the fuel pump figured out in a cost-effective manner. i though about fuel injection, but for now i will be using a carburetor in a blow through application, max 10 psi. any other issues with forced induction on the long block. i will probably use new rings, may or may not go for a full rebuild, but it would be a good idea. i know there are some flow issues with the stock head, i may look into a port job with bigger valves and a more aggressive camshaft. any other issues, ideas?
'59 Chevy 1-ton
'03 **** Lightning
