2 members (Buckeye998, J Lucas), 301 guests, and 2 robots.
Topics128,152
Posts1,057,012
Members48,460
I want to put a newer rear end under my 48 2 ton truck or at least update brakes to bendix.
any ideas appreciated, thanks
I just finished a 1946 chevy pickup street rod
now on a 1950 chevy 3100
also a GMC 220 with duals
and a 1948 chevy 2 ton
Crusing in the Passing Lane
What wheel bolt pattern do you have? Look for something modern with the same bolt pattern, modern brakes.
Ed
Some tidbits about replacement rear axles in this tech tip.
https://www.stovebolt.com/techtips/bigbolts/p30swap/
Better idea (than in above tech tip) for disc brakes on the front in this thread.
https://www.stovebolt.com/ubbthread...4-1-1-5-and-2-ton-trucks.html#Post725027
•1952 Chevrolet 3800 pickup
---All pictures---
is there a way to update brakes without changing everything else? I've read about updating the rearend in a 1 ton, was hoping I could do the same for the
rearend in my 2 ton
Swapping the rear complete for one from a 1.5 ton might get you better axle gears, but check ratios first, some are same.
Swapping brakes around for a few years newer drums might work, but also not likely worth the effort, minimal improvement.
What are you trying to do, or why?
---All pictures---
O.K. I have a 48 gmc 1 ton . I read about how hard it is to find parts 4 huck brake parts and that it was worth the effort to update brakes to bendix. I assumed my 2 ton would be the same way. My 2 ton that I just bought
has no brakes and i thought it mite be easier to just put a newer rear end under it. just looking 4 ideas on what to do. thanks Grigg for your help!
