| | | Forums66 Topics128,167 Posts1,057,017 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: May 2016 Posts: 56 | I want to put a newer rear end under my 48 2 ton truck or at least update brakes to bendix. any ideas appreciated, thanks
I just finished a 1946 chevy pickup street rod now on a 1950 chevy 3100 . also a GMC 220 with duals and a 1948 chevy 2 ton | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | What wheel bolt pattern do you have? Look for something modern with the same bolt pattern, modern brakes.
Ed
| | | | | Joined: May 2016 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: May 2016 Posts: 56 | is there a way to update brakes without changing everything else? I've read about updating the rearend in a 1 ton, was hoping I could do the same for the rearend in my 2 ton
I just finished a 1946 chevy pickup street rod now on a 1950 chevy 3100 . also a GMC 220 with duals and a 1948 chevy 2 ton | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Swapping the rear complete for one from a 1.5 ton might get you better axle gears, but check ratios first, some are same. Swapping brakes around for a few years newer drums might work, but also not likely worth the effort, minimal improvement.
What are you trying to do, or why? | | | | | Joined: May 2016 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: May 2016 Posts: 56 | O.K. I have a 48 gmc 1 ton . I read about how hard it is to find parts 4 huck brake parts and that it was worth the effort to update brakes to bendix. I assumed my 2 ton would be the same way. My 2 ton that I just bought has no brakes and i thought it mite be easier to just put a newer rear end under it. just looking 4 ideas on what to do. thanks Grigg for your help!
