6 members (GRNHydra, Greg_H, dunfire, Ponchogl, TPR57C, stlcardinalsguy), 136 guests, and 1 robot.
Topics128,030
Posts1,055,430
Members48,422
#1287174 11/12/2018 6:06 PM
Looking for assistance in identifying a 235 engine.
From the head and block casting numbers, appears to be 1956-1962
3836848
3769716
The number behind the starter is L 13 1 <--- Dec 13, 1951 or 1961???
Best I can read the serial number behind the distributor is I2I4B <--can find
Intake 8754844
Exhaust 8885587
Also found B54 848 850
Oil filler is in the center of the cover.
I've looked at some of the sites for decoding the numbers, but the serial numbers/date code don't seem to line up with the formatting, etc.
Thank you in advance!
Ron and Ryan Hill
1952 Chevy 3100
3836848 - 1956-1963 head casting code
What is the date casting code - see link below - that code is inside/under the valve cover)?
3769716 - 1958-1962 235 block casting code
Date casting code: L 13 1
L = 12 = December
13 = 13th day
1 = 1961 (1951 was a low pressure block - it would not be able to be used with an "848" head)
http://www.1954advance-design.com/Stovebolt-engine/casting-numbers.html
http://www.1954advance-design.com/Web%20images/casting-code-photos/codes-ser-nums.html
L 12 1 under the valve cover
Ron and Ryan Hill
1952 Chevy 3100
One day younger than the block.
Any way of knowing if it is a truck or passenger car?
Ron and Ryan Hill
1952 Chevy 3100
Thank you Tim! Passenger car it is!
Ron and Ryan Hill
1952 Chevy 3100
Y
Olddog
Olddog
Y Offline
Can anybody help me on what 1948 GMC truck I have? Number on engine and title are the same, is it a 3100? Any info greatly appreciated. Respectfully, Mike.
Y
Olddog
Olddog
Y Offline
Engine serial number A228I94608.
1/2 ton, 3/4 ton.
Yankabilly - it is best to start a new topic, when posting a new/different question.
You cannot determine the model GMC truck from the Engine Serial Number
A228I94608 - A 228 194608
A228
A = modifications to the engine/block from "normal" (marked at the engine plant)
228 = 228 engine
194608 = sequence number
If there is an ID plate on the driver's door jamb, that will hold the series/model code.
Unfortunately, many states (and DMV offices) used the Engine Serial Number for registration/title purposes.
This does not uniquely ID the truck, and does not ID the model of the truck).
Y
Olddog
Olddog
Y Offline
My apologies for not understanding I should start a new topic, old and slow I guess.
However, I do thank you, and appreciate all help.
Yankabilly.
