9 members (klhansen, rfs56trk, Bill Hanlon, 1955 1 Series, DHedrick, Otto Skorzeny, 39Master85, greenie-reddy, Peggy M), 136 guests, and 3 robots.
Topics128,087
Posts1,056,399
Members48,442
Hello everyone, I could not find in the search anything related to this. I have the 261 engine and had been firing up no problem for over a year. The last time I started it after I had made some adjustments it was great. The next day I go to start it and the key was left on, and now it will not fire, just turns over?! Any help would be great as I do not want to waste a lot of time trying to figure this out. There is plenty of gas in the tank and when turning over you can smell the fuel. I tried started with and without the choke possibly thinking it was flooding but to no avail.
1938 Chevy 3/4-Ton
In the DITY Gallery
1938 Chevrolet 1.5-Ton
Gonna be a classic farm truck
In the DITY Gallery
You may have burned your points. Check/replace those first and then see if it will start.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
If the engine stopped with the points closed and the ignition was left on, they're toast. Pop the distributor cap off and examine the points- - - - -I'll wager you're going to find them black and rough, unable to flow enough current to make the coil operate. You might get by temporarily by filing or sanding them, but that's only going to be a temporary fix for troubleshooting purposes.
Great, I will check those! Thank you Kent!
1938 Chevy 3/4-Ton
In the DITY Gallery
In the DITY Gallery
Ok, hopefully not but will definitely check there. Thank you Jerry!
1938 Chevy 3/4-Ton
In the DITY Gallery
In the DITY Gallery
Either the points or the coil, I did this once turned out to be both. Coil was hot to touch,points burnt black and welded together.
!956 Gmc Napco 4x4 Factory line built .
I agree with coil and points!
Riding in the Passing Lane
I did that once with Petronics ign. Blew the coil wide open. Lucky didn't start a fire. Oil was all over.
George
1972 Chevy c10 Cheyenne Super
