2 members (NJC, Cosmo), 61 guests, and 1 robot.
Topics128,050
Posts1,055,643
#1287603 11/16/2018 1:04 AM
1951 chevy 3100
1951 chevy 3100
I have a 1951 3100 truck. the engine stamp is F0914B trying to determine what size it is and year.
Dankjt #1287609 11/16/2018 1:48 AM
It's a 1957 and up 235 out of a passenger car with Powerglide trans.
F0914B
F = Flint
09 = Month
14 = Day
B = 235 Passenger Car w/ Powerglide
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #1287809 11/17/2018 11:08 AM
1951 chevy 3100
1951 chevy 3100
Thanks Mike I appreciate it.
Dankjt #1287811 11/17/2018 11:14 AM
62401
Dankjt -- You might want to ask (in the engines forum smile ) if there is anything significantly different about the 235 blocks cast for the Powerglide tranny. I can't remember, but there might be. Otherwise, I wonder why they would bother to differentiate between Powerglide and non powerglide engines ohwell
Could be an interesting bit of knowledge for all of us, as well as useful info about your own engine. I don't claim to know much, but what I have learned is that the info contained in the casting numbers, etc is significant and put there for a reason.
Welcome to Stovebolt!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Dankjt #1287819 11/17/2018 1:38 PM
Moderator
Moderator
2 Offline
Just a guess, but could it have something to do with the pilot hole?
Not there or no bushing?
Oh, and also welcome to the garage!!
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
John Milliman #1287853 11/17/2018 5:08 PM
All Powerglide-equipped vehicles with 235 engines (1950 and later) used 235 engines with hydraulic lifters (except the 235-equipped 1953-55 Corvettes).
Hydraulic lifters in all Powerglide-equipped low-pressure 235s from 1950-1953, and high-pressure 235s from 1953 and later.
Mechanical lifters were used in all 216/235/261 truck engines: in low-pressure/high-pressure engines, except, maybe, in 1960 and later 235s in trucks equipped with the Powerglide transmission.
Dankjt #1287904 11/18/2018 12:38 AM
I don't know about any other W/Powerglide 235s, but the '53 W/Powerglide requires a special pilot bushing for the end of the crankshaft. Or you could have the machine shop make the hole large enough to accept a stock pilot bushing.
John Milliman #1287908 11/18/2018 12:47 AM
1951 chevy 3100
1951 chevy 3100
thanks
Dankjt #1287910 11/18/2018 12:54 AM
1951 chevy 3100
1951 chevy 3100
My truck has a manual transmission. The number on the engine F0914B . Which in earlier post Mike said was powerglide transmission in passenger car. So I can assume the engine was replaced. Transmission original? I am very new to this.
Dankjt #1287950 11/18/2018 6:15 AM
I don't think you told us what transmission you have...is it a 3 or 4-speed, or an automatic???
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B #1287961 11/18/2018 12:49 PM
1951 chevy 3100
1951 chevy 3100
i beleive it is a 3 speed.
Dankjt #1287967 11/18/2018 2:13 PM
Moderator
Moderator
2 Offline
Dan
Check your PM's.
Red flashing letter next to your handle.
Don
"The Flag Pole"
1953 1-ton pickup
Dankjt #1287969 11/18/2018 3:02 PM
62401
Thanks Tim for the actual answer to the question.
smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
52Carl #1287972 11/18/2018 3:32 PM
smile
Thank Carl, too
He provided the other pertinent difference.
This old post might also help; but, it might also confuse?
