| | | Forums66 Topics128,087 Posts1,056,112 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | Is there a way to use a bed from a later model short bed on my 46'? I see that the later ones are wider. That would suggest that the fenders would not match up with the running boards. Of course the tail gate would need to be tossed as would the head board. As well as the cross rails. Has anyone done this ? Is it even worth the trouble? Mar K does make a pretty nice kit.
Trombones Totem Poles And Old Trucks!
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I owned my first antique truck (1942 Chevy half ton) for two months before I realized that the bed was a later '53 version, with the side mount spare tire. I was really new to the hobby and had no idea when I bought it. To mount the bed they had to cut the nice running boards about one inch shorter at the rear. The bed has the 53 fenders; I don't think your original fenders will fit at all.
I bought a Mar K bed for my '37 project as the original was just too beat up and it is very impressive. I would highly recommend you go that route.
Kent | | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | Thanks. I think you are right about Mar K. I'll probably go that route. But I also wonder about making a half ton short stake bed. I've never seen it done I don't think.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | The stake beds are handy.....try it and let us know how it works!
.... I second the Mar-K suggestion and I'll throw in another idea. I have seen later model beds with the flare fenders from rangers or S-10's that were tastefully done and looked good but have not seen one on a 46 Art Deco style. | | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | My plan is put an 8' bed on my 41 3/4 ton, from a '66 Jeep. I've measured it several times and know I will need to make several modifications, including adapting the mounting brackets/braces. I'm also putting dual wheels on the rear axle, so I will need extend the rear fenders out to accommodate that, as well as modifying the running boards. All that is to say, you can do almost anything. "Is it even worth the trouble?" you ask? - - - - I'll let you know when I get it done.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | |
