| | | Forums66 Topics128,066 Posts1,055,871 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | When I replace the floor with new patch panels I also plan to replace the front bolts that attach the cab to the frame. Here is the question since the floor on my truck is gone... I can't tell if the cab mount bolts go through the floor or does the florr cover them??? | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | yes theres a big metal cup that goes under the bolt if you order a cab mount kit you will get that part and new bolts | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | One question if you have new floor panels have you ordered the cab support panels that go under them? It sounds like yours may be missing, you want to do this work first if you can. it is much easier to weld these on with the replacement panels out of the truck. | | |
