6 members (Hotrod Lincoln, Peggy M, klhansen, IHPWR, DadsFirstPickup, 49choptop), 87 guests, and 1 robot.
Topics128,043
Posts1,055,605
#128614 10/15/2007 7:58 PM
We blasted our "Howie" 1946 Chevy 3/4 ton cab on the weekend... We have 2 problems...
1-Small hole about the diameter of your pinky finger near the hole where the windhshield wiper goes
2-Hole of about 3 inches long and about 1/16 inche wide running in the channel where the windshield sits in near the roof of the cab.
Any suggestions as to what to do with these?
Tempest
"Find Your Inner Truck"
Silly Boys! - Trucks are for Girls!
1945 2-ton
1946 3/4-ton
1951 Chevy 2-Ton
Redliners Auto Club
What\'z It
Snow Cruisers
#128615 10/15/2007 8:10 PM
Anonymous
Unregistered
Anonymous
Unregistered
Do you have a MIG welder? The metal in the window channel should not be too hard to form on a standard vise. Trim it to fit and weld it in. The hole on the top of the cowl could also be patched with a simple to form patch from thin gauge sheet metal.
Without pictures of the problem areas I am just going on perception.
#128616 10/15/2007 8:27 PM
Quote
Thats kinda what I was thinking... I have pictures... but I am behind the times and still use a 35 mm. Hope to have pics tomorrow....
Tempest
1945 2-ton
1946 3/4-ton
1951 Chevy 2-Ton
Redliners Auto Club
What\'z It
Snow Cruisers
#128617 10/15/2007 9:23 PM
If the holes your talking about are no larger then say, your index finger, just use a backing plate (for the windshield sill) of a different metal like brass, and weld new metal in. No need for patches.
Good luck and post some pic's and I'm sure their will come a solution.
HC
57' Chevy 3100 Stepside
http://www.cardomain.com/ride/2630531
#128618 10/17/2007 8:30 AM
The one on the cowl may be for the original radio antenna.
Paint & Body Shop moderator
#128619 10/18/2007 4:16 PM
Quote
didn't have a radio
Tempest
1945 2-ton
1946 3/4-ton
1951 Chevy 2-Ton
Redliners Auto Club
What\'z It
Snow Cruisers
#128620 10/25/2007 9:06 PM
click
The above is a pic of the cab and it's holes....
Tempest
1945 2-ton
1946 3/4-ton
1951 Chevy 2-Ton
Redliners Auto Club
What\'z It
Snow Cruisers
#128621 10/25/2007 10:16 PM
Oh, sorry, misunderstood your terminology. None of those holes belong there.
It might be easiest to get that section out of a donor cab and replace it rather than trying to close up all those holes. The slits would be from rust and the surrounding metal is going to be thin.
#128622 10/26/2007 2:04 AM
I think you could fill or patch with a MIG. You need to have access to the back. For filling, I would create a bunch of little spatters around the edge until you have enough metal to start a puddle. I would use a hunk of flattened copper pipe behind. It doesn't have to be pretty, just fuctional.
1951 1 Ton Completed
#128623 10/26/2007 1:59 PM
Patching with a MIG is always good advise however be prepared for a small problem becoming a bigger problem. Will take a pro's touch to keep that thin rusty steel from becoming swiss cheese. I always like to fix holes with steel but when I risk opening up a can of worms I resort to canned fiberglass. I too am fixing similar holes in my 55-3/4 ton this weekend. Found some fiberglass paste made from milled fiberglass rather than short strand. Should be easy to work with. Fiberglass over epoxy primer. Good waterproof fix.
Good luck with the repair...and remember to have fun!
Keith
#128624 10/26/2007 10:11 PM
Mike is good with the MIG welder... he works in a body shop, but suggested that I come and ask if anyone had experienced this and what they did.. Thank you all for your suggestions.
Tempest
1945 2-ton
1946 3/4-ton
1951 Chevy 2-Ton
Redliners Auto Club
What\'z It
Snow Cruisers
