0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2018 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2018 Posts: 38 | Can someone please give me the dimensions of where to drill to install new tailgate chains on a 57 3200? Hoping to get the exact location to drill and any other tech tips, like drill bit size etc.
I know this seems like its an obvious answer, but I have a truck that came without tailgate latches, I ordered some and they have no instructions and I cannot find any searching this forum or google. Images do not show me much on google either. There is lots of info for the new hidden latch installs - but I like the chains.
57 Chevy 3200 | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Maybe check the gallery on this site for pictures of similar trucks. At least you'll have a starting point. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 |
Evan
| | | | | Joined: Oct 2018 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2018 Posts: 38 | Thanks for the reply's. Yes Ive looked at photos. I was just wanting to make are I did it correctly - as my truck seems to have all the original holes cover up from a hot rod era. I was hoping for something like drill a 1/2 inch hole through the truck sides, 2" down and 1.5" in or something. Ive search photos and its hard to zoom in to get the detail of where the eye hook is attached.
Can anyone hold up a tape measure next to theirs and take a photo?
57 Chevy 3200 | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | do you want the location of the hole for the eye? be specific and i'll take a picture of my truck for you. | | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | The eye bolts on the frame of my 56-3200 are 4 and 5/8 down from the under side of the flat side of the top rail; you can measure from just inside of the curled edge. And 1/2 inch in from the side edge. They look just like the picture you found. I think the most important part of the location is that you need to make sure that they do not interfere with the tailgate piece with the long slot. As you can see in the picture they are pretty close and mine have only about an 1/8 inch separation. Good luck.
1956 Chevy 3200, 235 w/3 speed
| | | | | Joined: Oct 2017 Posts: 54 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 54 | The bolts on my truck are square to prevent turning in the hole which is also square.. They look like those listed in pic above. My truck is a 1959 stepside.
1959 Apache 31
