4 members (52Carl, klhansen, Bill Hanlon, farmallb), 334 guests, and 5 robots.
Topics128,159
Posts1,057,037
Members48,460
i don't know enough about its looks to just try to yank it out. I'm not able to remove pan and cover now to change out. thanks 4 any help.
https://postimg.cc/gallery/23qug4khy/
Yes- - - -just drill a small hole in the seal and use a sheet metal screw to pry against. Be careful not to bend the cover while tapping the new seal into place. Inspect the balancer snout for wear and install a "speedy sleeve" if necessary to give the new seal a smooth surface to work with. The seal and speedy sleeve for a small block V8 also fits the 216/235/261 engines, and I believe the GMC's also use that seal.
thanks, went to oriellys and matched it. it looked odd to me because it was so thick and sticking out beyond the t-cover.
