| | | Forums66 Topics128,151 Posts1,057,001 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2018 Posts: 92 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 92 | i don't know enough about its looks to just try to yank it out. I'm not able to remove pan and cover now to change out. thanks 4 any help. https://postimg.cc/gallery/23qug4khy/ | | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | Yes- - - -just drill a small hole in the seal and use a sheet metal screw to pry against. Be careful not to bend the cover while tapping the new seal into place. Inspect the balancer snout for wear and install a "speedy sleeve" if necessary to give the new seal a smooth surface to work with. The seal and speedy sleeve for a small block V8 also fits the 216/235/261 engines, and I believe the GMC's also use that seal. Jerry
| | | | | Joined: Sep 2018 Posts: 92 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 92 | thanks, went to oriellys and matched it. it looked odd to me because it was so thick and sticking out beyond the t-cover. | | |
