Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Otto Skorzeny, 55shaker, Ribside), 128 guests, and 5 robots.
Topics128,281
Posts1,058,478
Members48,490
#128349 09/29/2007 4:57 AM
I have been told that you can't use filler over metal that has been treated with an acid wash. The inner fenders were sand blasted and I then treated them with a product named Jasco Prep and Primer. I brushed it on them and let it dry. Does anyone know if I can fill over this product?
#128350 09/30/2007 2:54 AM
i have been dooing some research on metal wash (acid) and i am told to cover it with epoxy primer to seal it in , then fill.
layback
#128351 10/01/2007 3:56 AM
I have found the De beerer epoxy primer to be very good and hard wareing and seals real well .
#128352 10/07/2007 3:49 AM
Jerry d:
I usually scuff up the metal that has had the acid wash (phosphoric acid) before I apply filler. Once the filler is applied direct to the metal, I epoxy prime over the top of it. I haven't had any problems with this method.
regards
Steve Lorio
New Orleans
#128353 10/07/2007 4:05 AM
I have since I originally posted this question done some research on it. I read the label and it said you could prime or fill directly over it. Just shows the old addage of if all else fails read the directions.
