8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible),
67
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,014 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 17 New Guy | | New Guy Joined: Jul 2007 Posts: 17 | I have been told that you can't use filler over metal that has been treated with an acid wash. The inner fenders were sand blasted and I then treated them with a product named Jasco Prep and Primer. I brushed it on them and let it dry. Does anyone know if I can fill over this product? | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | i have been dooing some research on metal wash (acid) and i am told to cover it with epoxy primer to seal it in , then fill.
layback
| | | | | Joined: Dec 2002 Posts: 39 Member | | Member Joined: Dec 2002 Posts: 39 | I have found the De beerer epoxy primer to be very good and hard wareing and seals real well . | | | | | Joined: Jan 2007 Posts: 93 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 93 | Jerry d: I usually scuff up the metal that has had the acid wash (phosphoric acid) before I apply filler. Once the filler is applied direct to the metal, I epoxy prime over the top of it. I haven't had any problems with this method. regards Steve Lorio New Orleans | | | | | Joined: Jul 2007 Posts: 17 New Guy | | New Guy Joined: Jul 2007 Posts: 17 | I have since I originally posted this question done some research on it. I read the label and it said you could prime or fill directly over it. Just shows the old addage of if all else fails read the directions. | | |
