| | | Forums66 Topics128,042 Posts1,055,509 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 11 Junior Member | | Junior Member Joined: May 2007 Posts: 11 | Hello Folks My 55 One ton has a perfect body (except for about a half a dozen small rust spots). Fairly heavy pitting but no where near rust through. My question, has anyone had occasion to use any of the following products. 1 Step Rust Killer, Rust Doctor, or Zero rust?? Several coats of one of these products would probably fill my problem areas, Any input would be appreciated Thanks Bob  | | | | | | Anonymous Unregistered | | Anonymous Unregistered | None of those products will fill your pits but they all work well in containing rust. My preference is the Zero Rust. Easy to use and less expensive. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Are you painting it or just trying to prevent it from spreading?
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: May 2007 Posts: 11 Junior Member | | Junior Member Joined: May 2007 Posts: 11 | Houston 54 I will try the Zero rust. thank you and to 4 on the floor There will be new paint in the future, it will be a daily driver. | | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | I am a Zero Rust fan myself. I never had heard of it until I started reading all the post from these old truck experts here. I think I have been getting it for like 50$ a gallon and it if holds up as good as some folks say, i will feel it will be well worth it. I was thinking of creating some sort of spray bomb so I could coat the inside of my doors and places I can't spray this stuff with my paint gun. I may try some in a garden sprayer, no kidding, to reach down into the door of my truck. I am sure you know, or have heard this, but always wear a mask to protect you lungs and stuff. Something to protect you eyes too.
Best to ya..
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I personally have never used zero rust. I have POR15 and I love that stuff. I just (finally) coated my panel chassis and once again I am amazed at how good POR15 looks and how tough it is. (I blasted the chassis before coating)
So, for someone who has used BOTH zero rust and POR15....what do you see as the deciding factor of one over the other??? | | | | | | Anonymous Unregistered | | Anonymous Unregistered | POR is probably more durable in the long run and if you spend time lying on your back marvelling at the beauty of the bottom of your rig then it may be worth it.
ZR is available in rattle can, qts and gallons in various colors and will not kill you if you breathe it in as POR will. ZR is also less expensive, easier to apply, easier to get off your skin and does the job it is intended for. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | they have this stuff at the hardware store that has acid in it spray it on and it turns the rust into something black that can be scraped off and sanded it kills rust and turns it inurt its something like ocfoce its in the paint area its cheape for a big spray bottle i would use it then a rust treatment | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | POR has the acid based cleaner & degreaser system apply by brush is safer than spray i did my whole frame on our 51 and it looks great. i also did the inner fenders, lots of little brackets under the frame, linkages, under bed gas tank & more. tooooo bad the painter did some overspray and screwed it up in spots do gloss on the frame as it will dull (a bit) in years but still look great NOTE: por does NOT like sunlight  so ALL areas must be hidden so NO bumper arms, {running board tops & front apron skirt tops, (i did the bottoms)}  .
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Has anyone used Rust Encapsulator from Eastwood. I have been using it on areas where I weld or grind and it seems to work OK. I top it off with Rustolem gloss black.
~Jim
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Where do you find Zero Rust?
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ask them where your nearest distributor is - good stuff Bill | | | | | | Anonymous Unregistered | | Anonymous Unregistered | This is where I buy my ZR products. Best price and quick shipping. \http://www.raybuck.com/ | | |
