2 members (Peggy M, 59 fleet), 87 guests, and 4 robots.
Topics128,096
Posts1,056,489
Members48,444
#1282672 10/06/2018 1:40 AM
** Am having trouble getting a recently rebuilt 261 started. {First Start} - Valve lash set to specs - timing set to specs - all six spark plugs have good spark - known good carb installed but engine will not start. Not as much as a pop with above settings. If I retard the distributer {counter clockwise} as far as it will turn the engine acts like it wants to start but won't. Have checked and rechecked all settings but still no start. If anyone has any thoughts that might help all greatly appreciated. Thanks
You have spark......have you looked down the throat of the carb and verified it is getting gas. I know its an elementary question but just had to ask.
Basics, basics, basics. Make absolutely sure you have the distributor rotor pointing to #1 plug wire when engine is at TDC on the compression stroke.
How did you determine tdc for no. 1 plug/cylinder when you dropped the distributor in? Run a quick compression check. Just to make sure no issues with the timing gears and intake valves.
Mike
