1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 16 Junior Member | | Junior Member Joined: Mar 2007 Posts: 16 | I'm wondering if anyone can tell me a quick and simple (yeah right!) way to remove the inner cab on a 54' chevy. Back in the day when my uncle still owned the truck he backed under a tree and put a nice dent above the rear window where it curves into the roof. What I'm hoping to do is some hammer and dolly work to even it out as much as possible before I start smearing in filler.
-Owen
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | much easier to use a stud welder & pull the dent out | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I would go with the stud welder and puller first but you can always cut out the inner skin and the weld it back in after you fix the dent. The number of spot welds used to afix the inner skin to the cab can only be determined through advanced mathmatics. | | | | | Joined: Mar 2007 Posts: 16 Junior Member | | Junior Member Joined: Mar 2007 Posts: 16 | Thanks Guys, is there some way to pull off the same sort of thing with a regular welder (mig,tig,stick)?
-Owen
| | | | | Joined: Oct 2004 Posts: 40 Apprentice | | Apprentice Joined: Oct 2004 Posts: 40 | You could weld a 1/4x20 nut in the middle of the dent then use a slide hammer with a 1/4x20 bolt to pull it out. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | You could weld some good size nails to the dent and try a slide hammer on that. | | |
