2 members (Otto Skorzeny, dt235sd), 122 guests, and 1 robot.
Topics128,052
Posts1,055,719
#128180 09/18/2007 11:54 PM
Junior Member
Junior Member
I'm wondering if anyone can tell me a quick and simple (yeah right!) way to remove the inner cab on a 54' chevy. Back in the day when my uncle still owned the truck he backed under a tree and put a nice dent above the rear window where it curves into the roof. What I'm hoping to do is some hammer and dolly work to even it out as much as possible before I start smearing in filler.
-Owen
#128181 09/19/2007 12:01 AM
much easier to use a stud welder & pull the dent out
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#128182 09/19/2007 1:24 PM
Anonymous
Unregistered
Anonymous
Unregistered
I would go with the stud welder and puller first but you can always cut out the inner skin and the weld it back in after you fix the dent. The number of spot welds used to afix the inner skin to the cab can only be determined through advanced mathmatics.
#128183 09/21/2007 5:14 AM
Junior Member
Junior Member
Thanks Guys, is there some way to pull off the same sort of thing with a regular welder (mig,tig,stick)?
-Owen
#128184 09/21/2007 6:34 PM
Apprentice
Apprentice
You could weld a 1/4x20 nut in the middle of the dent then use a slide hammer with a 1/4x20 bolt to pull it out.
#128185 09/21/2007 6:40 PM
Anonymous
Unregistered
Anonymous
Unregistered
You could weld some good size nails to the dent and try a slide hammer on that.
