0 members (), 118 guests, and 3 robots.
Topics128,186
Posts1,057,320
Members48,469
Hi Guys,
I’m looking for 3.55 ring and pinion for my 48’ rear. Is Patrick’s still in business? I called the number and got no answer and the idea of getting the gears and all the other parts in one kit seems really easy for a novice like me. Anyway does anyone know of an other retailer that sells the gears and the other parts? Thanks
Do your due diligence on Patrick’s. Try using the Stovebolt search at the top of this forum. Just type in Patrick’s.🛠
Well after reading that thread about how Patrick’s screwed over so many customers is very disappointing. It’s getting harder and harder to trust anybody anymore! So does anyone have a reliable vendor for ring and pinion and other parts needed for a high speed rear? Thanks
Try Mothertrucker. Do a search for contact info.
** Got mine for a 53 chevy from Jim Carter within a few days after ordering it. **
Plus 2 on mother trucker.........
Haunting the SBP since 2001
MT is the importer. There will be no BS from MT.
Classic Parts sells an installation kit (which includes a tool or two).
A dial indicator and stand will be needed - available from Harbor Freight and others.
Read this Tech Tip several times - provided/written/produced by Chris.
More good info on the gear setup:
http://devestechnet.com/Home/DifferentialOverhaul
Thanks for all the info! I order gears from mothertrucker and install kit from classic parts. I’ll post my success or failure in about a month. Thanks for the help!
Got mine from Mother Trucker. I didn't initially buy an installation kit, but I ended up needing everything in the kit. I ended up buying the pieces separately and probably paid a penalty for it.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Wait, and save up your money, to be able to buy the installation kit.
My stock differential was in good condition, no issues. Did the 3:55 gear swap.
I did not buy the install kit.
Used the template on the DEVE site to make the spacer tool.
Purchased OEM shims to set the pinion depth. The bearing can all be reused and no pressing or cutting is required to swap the gears.
The irony of Patricks is, I sent him a letter long before computers asking about a gear change and he sent me back a scathing response for modifying my truck.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
So you sell the gears, but when a customer wants to buy them they get scolded. Seems like a strange business model! Lol. Anyway I got the gears and install kit on the way so hopefully things will go well with the swap. Be on the lookout for tech questions once I get into it. Thanks for all the help so far!
Hope it all works out for you. Got my 3.55 setup from Patrick's many years ago. One of the best mods I've done to the green turd.
Craig
