| | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | Does anyone have a pic of the center bow? I just installed my headliner and the PO had a sunroof that is now closed off The cardboard headliner has cutouts for screws but the center bow does not have holes and looks like it’s from a car Also, who carries original cab windlace? My 49’ Suburban has cloth ones that are sewn | | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | I just did the headliner in my 1950 3100. I'll PM you re: Pictures. PM sent with my number.
1950 Chevy 3100
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | There are two styles of these headliners available. The 1947- very early 49 center bow screws into a welded in top piece attached to the cab. The later versions do not have this attachment, they slide into the S-shaped bow securing at the front windshield trim and rear screw in bow. If yours has the screw holes you have the early version which is not correct for a 1950 truck application. | | |
