3 members (dt235sd, Bucker, UtahYork), 160 guests, and 4 robots.
Topics128,196
Posts1,057,390
Members48,471
I work on new cars, so this modern gear oil was free and available when I drained and refilled the old '65's granny four speed. Should I change it to old school 90w gear oil? Something about the synchros not working correctly?
It does grind sometimes in 4th if you get a little impatient with shifting, but I thought it was just the regular high mileage wear and tear.
Pic of Ol Blue: pix
[img]https://s6.postimg.cc/xd6uy3iy9/image.jpg[/img]
The gears in a SM 420 are big, heavy, and have a lot of inertia. A lubricant as slippery as synthetic gear lube is probably keeping the synchronizers from doing their job properly. Rice rockets with transmissions that would fit in a back pocket and gears that weigh a fraction of what's in a real transmission don't have that kind of inertia to deal with. Some people also think the new water-thin synthetic motor oils are OK to run in stovebolt engines- - - -WRONG!
Check out this Stovebolt Thread
It's a small world, but I wouldn't want to paint it.
