| | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2016 Posts: 10 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 10 | I work on new cars, so this modern gear oil was free and available when I drained and refilled the old '65's granny four speed. Should I change it to old school 90w gear oil? Something about the synchros not working correctly? It does grind sometimes in 4th if you get a little impatient with shifting, but I thought it was just the regular high mileage wear and tear. Pic of Ol Blue:  [img] https://s6.postimg.cc/xd6uy3iy9/image.jpg[/img]
| | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | The gears in a SM 420 are big, heavy, and have a lot of inertia. A lubricant as slippery as synthetic gear lube is probably keeping the synchronizers from doing their job properly. Rice rockets with transmissions that would fit in a back pocket and gears that weigh a fraction of what's in a real transmission don't have that kind of inertia to deal with. Some people also think the new water-thin synthetic motor oils are OK to run in stovebolt engines- - - -WRONG! Jerry
| | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 |
It's a small world, but I wouldn't want to paint it.
