0 members (), 247 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
Hey Bolters.
I'd like to know the pitfalls, if any, of swapping my distributor for an HEI on my 235.
I'd like to keep it as stock looking as possible so which one should I buy? I won't change out my genny for an alternator, so does this inhibit my ability to go HEI?
I searched the forum here and got frustrated looking for an answer... my apologies for posting this as I am sure the answer is buried somewhere within this forum.
Thanks in advance.
FootStomper
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
Sir Searchalot
Sir Searchalot
It's best to use the search here on Stovebolt. It's frustrating possibly, to search, find and read. It's also frustrating to read all the opinions that will ensue. Again.
All kinds of stories and opinions including staying with points.
Also:
1. Pertronix
2. Langdon
3. DIY 2.8 Buick conversion
4. Mini Mallory
5. Mini other
6. Modified Chevy 250 HEI
My opinion has always been, if you don't want points, buy a HEI from Langdon Company. That would seem to be the least headache, most proven and kind of stock looking. Anything GM is your best choice.
If you are really hard over on looking stock, the only one I know of is the Pertronix. It's not a true HEI and no parts available out on the road. Quality control shows iffy on the web. Hit and Miss.
You need to be a 12 volt system, HEI will not work with 6 volt unless you go to a 6volt pertronix
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
it's 12 Volt
~~ Darcy
FootStomper
Sir Searchalot
Sir Searchalot
Added edit, sorry
The simplest and least expensive HEI will be the 250/292 Chey distributor from a salvage yard. Other than doing a little tinkering with the mounting flange, it's almost a drop-in fit. The 2.8 Liter Chevy V6 ("Mini-HEI") needs some adjustment of the shaft length, and there's only a few of them out there with vacuum advance. The full electronic advance mini doesn't work without a computer onboard. Does the 3.8 L Buick/Olds even fire V6 distributor turn the right direction? (clockwise) I don't remember.
This is great Intel. Thanks!
~~ Darcy
FootStomper
Fox Offline
I got my HEI for my 261 from Langdon’s. Simple install. Fired right up. No problems so far and as mentioned above is “stockish looking.” Most people don’t notice. They are too busy pointing out my alternator! I’m happy with it. I think you would be too.
Here’s a picture of my HEI installed.
https://photos.app.goo.gl/p2BdxJBZ645AgJrS7
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
I bought the Langon unit and was happy with it for 10 years and then it was messed with, not by me and it still works fine but for my gas mileage issue.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Check out Deve's Technet
It's a small world, but I wouldn't want to paint it.
