0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
All,
I have seen folks ask this but not sure I ever remember hearing my solution for it...
I found that a strait razor, like what you would use to clean paint off of glass will cut old undercoating right off of the under side of body parts. Just lay it down just like you would if you were attempting to scrap the paint off. I was somehow able to get between the paint and the undercoating and pretty much cleaned it right off. I tried to use my wire wheel and that took too long the razor blade did just fine for me. In my case, I mounted it in a holder and went to chipping it away. Be careful not to cut yourself for sure.
Jesus is Lord!
Only through the blood of Jesus are you washed clean of your sins.
Come see us... Dad's Chevy
Our Video
God bless you! Michael..
I just went through this this past weekend. I'm trying to get the old undercoating off my fenders so I can paint them. Starting with a wire brush and a gasket scraper, I thought I was in for a very long process. Then I switched to a wide (1"?) wood chisel and like you said, it came off with no problems at all.
Check it out on my webshots page.
1950 Chevrolet 3100 "One Step Forward, Two Steps Back"
Webshot Photos
I am using a heat gun to warm up the tar undercoating than scaping with a putty knife and it seems to work faily quick.
Ed
I used the wood chisel trick too. I will try the razor trick next time
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
Be very careful of your hands when scraping with a straight razor blade, they are brittle and don't like undue force applied to them. I have a scar on my right index finger from the back of a broken razor blade.
I would use an old wood chisel sharpened to razor sharp.
Paint & Body Shop moderator
There's no easy way to do this. I borrowed a pneumatic undercoat removal tool from a friend (it's a circular wire brush) and it took the stuff off instantly (where the tool would fit). The rest of the stuff came off with eastwood undergone, a paint scraper and a lot of patience. I got half the cab done this weekend, will finish the rest next weekend. BTW - it's totally worth it.
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
If you don't care about the paint and can get a partner you can use a propane tourch on the opposite side of the undercoating. I did the entire floor of my '50 AD this spring in about 45 minutes. Old stuff rolls right off. Just heat it until it gets soft, no need to burn it. Keep moving the torch and scraping. I recommend doing this outside or with the overhead garage door open. Works great.
It never costs more to ask and it never costs more to think big.
I used Paint Stripper two good coats will work
Maxx
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
has anyone tried oven cleaner? It bubbles grease and grime right off!
Another quality post.
Real Trucks Rattle
