| | | Forums66 Topics128,050 Posts1,055,673 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | All,
I have seen folks ask this but not sure I ever remember hearing my solution for it...
I found that a strait razor, like what you would use to clean paint off of glass will cut old undercoating right off of the under side of body parts. Just lay it down just like you would if you were attempting to scrap the paint off. I was somehow able to get between the paint and the undercoating and pretty much cleaned it right off. I tried to use my wire wheel and that took too long the razor blade did just fine for me. In my case, I mounted it in a holder and went to chipping it away. Be careful not to cut yourself for sure.
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | I just went through this this past weekend. I'm trying to get the old undercoating off my fenders so I can paint them. Starting with a wire brush and a gasket scraper, I thought I was in for a very long process. Then I switched to a wide (1"?) wood chisel and like you said, it came off with no problems at all.
Check it out on my webshots page. | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | I am using a heat gun to warm up the tar undercoating than scaping with a putty knife and it seems to work faily quick.
Ed | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I used the wood chisel trick too. I will try the razor trick next time | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Be very careful of your hands when scraping with a straight razor blade, they are brittle and don't like undue force applied to them. I have a scar on my right index finger from the back of a broken razor blade.
I would use an old wood chisel sharpened to razor sharp.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 119 | There's no easy way to do this. I borrowed a pneumatic undercoat removal tool from a friend (it's a circular wire brush) and it took the stuff off instantly (where the tool would fit). The rest of the stuff came off with eastwood undergone, a paint scraper and a lot of patience. I got half the cab done this weekend, will finish the rest next weekend. BTW - it's totally worth it. | | | | | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | If you don't care about the paint and can get a partner you can use a propane tourch on the opposite side of the undercoating. I did the entire floor of my '50 AD this spring in about 45 minutes. Old stuff rolls right off. Just heat it until it gets soft, no need to burn it. Keep moving the torch and scraping. I recommend doing this outside or with the overhead garage door open. Works great.
It never costs more to ask and it never costs more to think big.
| | | | | Joined: Dec 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 92 | I used Paint Stripper two good coats will work Maxx
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
| | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | has anyone tried oven cleaner? It bubbles grease and grime right off!
