8 members (David Bush, kades51, BC59, MikeE, Bucker, MickeyP, Rexville48, dt235sd),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,702 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | I have a 1958 Apache 3100 currently undergoing a period correct frame-off restoration. I would like to know if the 'behind the seat' gas tank came painted from the factory and if so what color. The one removed from my truck was unpainted,
Thanks in advance. | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | To the best of my knowledge all of the behind the seat gas tanks were unpainted. Hope this helps. Jim | | | | | Joined: Jul 2018 Posts: 19 New Guy | | New Guy Joined: Jul 2018 Posts: 19 | My 56 3100 truck is mostly stock from my understanding and my gas tank is a light grey color.
56 Chevy 3100
| | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | Mine was kind of weird and I have never determined if it was 'factory painted' or not, but in case it matters: It had a grey color painted on it that perfectly matched the interior original paint (that was protected from later changes by being mostly inaccessible). It was hand-painted, and was applied on even the fuel line part that was accessible in the cab without the seat in place. The backside of the tank was bare steel.
It looked like the factory (or someone shortly thereafter) installed the tank, then hand-painted it to match the interior color.
Can PM you some pics if that helps.
-Jim | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The tanks are tin/galvanized coated metal, they were not painted. Mike B  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | On Advance Design (and New Design) trucks: I have seen them unpainted. And, I have seen them painted in-place, with no paint on the inside cab behind them. | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Thanks everyone for the information you have provided regarding gas tanks behind the seat. | | |
