7 members (Gdads51, SmalltownTRKGuy, SNOYL, Bill Hanlon, RoadsScholar, 78buckshot, lumbersawyer), 358 guests, and 4 robots.
Topics128,164
Posts1,057,078
Members48,463
#1275731 08/10/2018 7:38 PM
Just saw this weatherstrip on a '53 truck for sale. I've owned three AD trucks, none of which had this. Is this OEM or did someone add it? Should I add it to my truck?
1951 Chevy Panel Truck
That weatherstrip is O.E. It helps with road drafts and dust.
I think I see three places where there might have been “weather strip”?
- on the outer cab, below the door opening
- between the running board and the cab
- on the bottom of the inside edge of the door
Yes, I should have clarified, I'm inquiring about the one on the cab floor sill that looks like a garden hose held on by a sill strip. I know the one on the door bottom is original equipment, so it seems like the "garden hose" one is redundant.
Sir Searchalot
Sir Searchalot
https://www.chevsofthe40s.com/blog/how-to-install-1937-46-12-ton-windlace-door-sill-seal/
This says 37-46. The video shows the seal plate/rocker comes off with screws and the seal is retained by it. Maybe 53 is same or the previous owner used a 46 seal??
DADS50 #1275766 08/11/2018 12:45 AM
Thanks!
That's surprising. I've owned three ADs and none of them had that - not even the strip that holds it. Maybe it was an option?
Originally Posted by miraclepieco
Thanks!
Nope. That lower windlace was original equipment on all '50-'55.1 AD trucks. Earlier years also had them, but they were of a different style which were screwed into the side of the rocker panel, rather than through the top like in your picture.
This windlace seal is necessary to make up for the highly variable fitment of the door at the bottom where the door seal is compressed so tightly by the retainer that it does not seal much, if anything.
Carl
My 53 had it and surprisingly in pretty good shape.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
https://lh3.googleusercontent.com/J...UcKDgGqgxqBf-F5MG8RDoOvV0U=w1121-h840-no
There are a few more photo's in the Google photos....click on link below.
My '50 has remnants of those.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
