1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1275697 08/10/2018 12:25 PM
putting a 1958 235 in a 49 pickup, question what throttle bellcrank do you use ? the one off the 216 or off the 235. Thanks
Ted Skidmore #1275717 08/10/2018 3:30 PM
I'd use the one off the 216:
If you are staying at 6v on the 1949 (using the 6v starter), use the 216 pressure plate, clutch-assembly, and throwout/release bearing.
Ted Skidmore #1275718 08/10/2018 3:38 PM
and flywheel
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Ted Skidmore #1275722 08/10/2018 3:54 PM
Thanks, sstock
Ted Skidmore #1275723 08/10/2018 3:55 PM
The question what throttle bellcrank do you use for the gas pedal ??
Ted Skidmore #1275725 08/10/2018 4:08 PM
The answer (from above): "I'd use the one off the 216"
Ted Skidmore #1275786 08/11/2018 2:11 AM
I believe that the stud for bellcranks of a 235 and a 216 are in different locations on the block. I do not know if the actual bellcranks are the same or not. I am guessing that they are not.
You can drill and tap the block for the correct location for the 216 bellcrank stud on your '58 block. You can probably do a search and find directions for that.
Carl
Ted Skidmore #1275797 08/11/2018 2:32 AM
There's a good picture with a little blerb about relocating the stud, as 52Carl mentioned above. Page 6.
bell crank stud
Way more cool 6-cylinder Chevy info there too.
Professional Novice
Ted Skidmore #1275813 08/11/2018 8:00 AM
If you move the bellcrank you will have to lengthen the accelerator rod. I took a different path. Used the 235 bellcrank location. Ran the rod up and between the manifolds and welded a bolt to the rod end, going straight forward to the carb linkage. Put a nut on both side of the carb linkage so I didn't add a twist motion. Then I added some length to the vertical rod. Still works good after 30,000 miles. If I were doing it again, I would opt for the relocated bellcrank.
Fred
52 3600
69 C-10
