| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 79 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 79 | putting a 1958 235 in a 49 pickup, question what throttle bellcrank do you use ? the one off the 216 or off the 235. Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I'd use the one off the 216:
If you are staying at 6v on the 1949 (using the 6v starter), use the 216 pressure plate, clutch-assembly, and throwout/release bearing. | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2007 Posts: 79 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 79 | The question what throttle bellcrank do you use for the gas pedal ?? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The answer (from above): "I'd use the one off the 216" | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | I believe that the stud for bellcranks of a 235 and a 216 are in different locations on the block. I do not know if the actual bellcranks are the same or not. I am guessing that they are not. You can drill and tap the block for the correct location for the 216 bellcrank stud on your '58 block. You can probably do a search and find directions for that. Carl
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | There's a good picture with a little blerb about relocating the stud, as 52Carl mentioned above. Page 6. bell crank studWay more cool 6-cylinder Chevy info there too.
Professional Novice
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you move the bellcrank you will have to lengthen the accelerator rod. I took a different path. Used the 235 bellcrank location. Ran the rod up and between the manifolds and welded a bolt to the rod end, going straight forward to the carb linkage. Put a nut on both side of the carb linkage so I didn't add a twist motion. Then I added some length to the vertical rod. Still works good after 30,000 miles. If I were doing it again, I would opt for the relocated bellcrank.
Fred 52 3600 69 C-10
