0 members (), 121 guests, and 5 robots.
Topics128,187
Posts1,057,212
Members48,465
I just got the new floorpan/toeboard pieces for Dad's 51 Chevy 3100. As I went to do a test fit, I noticed that they have the depressions and holes for the clutch and brake seals, but not the sheet metal "holder" pieces that hold the actual felt/leather seals. :confused: The same holds true for the accelerator--there's no "holder", nor is the pivot or pedal stop there. Soooo, does anyone make this stuff aftermarket, or am I doomed to drill out the spotwelds, attempt to salvage these pieces and reweld them on the new floorpan pieces? frown Thanks, Chris
it's a salvage job, not too tough
That's what I did. I used the holders from the old floor. Very easy. A couple of spot welds to drill. Then I used the same holes that were drilled to plug weld them on the new floor.
I appreciate the info, guys. As far as gettin' 'em out, well, I figured that'd be what I was in store for. But, I also figured that if someone sold 'em repop, I'd probably shell out a few bucks to get 'em... Thanks again, Chris
Anonymous
Unregistered
Anonymous
Unregistered
Who's did you get? were they the overseas black ones or the USA gray ones? how did they fit otherwise?
