0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1275629 08/09/2018 5:48 PM
I received a rebuilt one barrel Rochester carburetor form Chevy of the forties and had it installed. I also placed an insulator between the carb and the intake manifold. The heat here is in the 110s. On acceleration the carb flatttens out and then acellerates. I follow the advice of the person who rebuilt the carburetor with no results. I can’t have the shop open the carburetor, under penalty of death, as they won’t guarantee the the work. Is there anyone who is reliable that I can go to for a carburetor?
As they don’t make these NEW maybe change to a two barrel for my 235.
flyn55 #1275630 08/09/2018 6:10 PM
H Online: Content
The problem is in the first sentence of your post- - - - -"Rochester". Find a correct Carter YF carburetor for your application, install it, and drive on- - - -problem solved! Two barrels on a 235 is one too many. The only possibly worse choice would be two one-barrel carburetors.
flyn55 #1275631 08/09/2018 6:24 PM
Carburetion specialist
Accelerates from a stop???
Accelerates from cruise speed going up a hill or passing a slower vehicle???
If possible, avoid ethanol fuel like the plague if you have to drive in temperatures of 110 degrees!!!
Jon
The Carburetor Shop
