1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 40 'Bolter | | 'Bolter Joined: Nov 2007 Posts: 40 | I received a rebuilt one barrel Rochester carburetor form Chevy of the forties and had it installed. I also placed an insulator between the carb and the intake manifold. The heat here is in the 110s. On acceleration the carb flatttens out and then acellerates. I follow the advice of the person who rebuilt the carburetor with no results. I can’t have the shop open the carburetor, under penalty of death, as they won’t guarantee the the work. Is there anyone who is reliable that I can go to for a carburetor? As they don’t make these NEW maybe change to a two barrel for my 235. | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | The problem is in the first sentence of your post- - - - -"Rochester". Find a correct Carter YF carburetor for your application, install it, and drive on- - - -problem solved! Two barrels on a 235 is one too many. The only possibly worse choice would be two one-barrel carburetors. Jerry
| | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Accelerates from a stop???
Accelerates from cruise speed going up a hill or passing a slower vehicle???
If possible, avoid ethanol fuel like the plague if you have to drive in temperatures of 110 degrees!!!
Jon Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
