1 members (klhansen),
70
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | I have recently found a fix for the ongoing problem of sealing up the fentons to the exhaust pipes. The regular donuts we've all used don't seem to do the job or not for long. Walker makes a tapered insert with a short pipe extension that fits inside the downpipe that help to align the pipe to the Fenton's. (Walker PN 31524)
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | Are you using Remflex gaskets? They solved my problem, and they are cheaper on Amazon--Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bill,
"problem of sealing up the fentons to the exhaust pipes" "Are you using Remflex gaskets?"
Are you referring to the Remflex gasket between the manifold assembly and the head, or are you referring to a different Remflex gaskets for the Fenton's to the exhaust pipes?
What is/are the Remflex part number(s) for those gasket(s)?
| | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | we used RFL-2027 Exhaust header gaskets 39.19 Is that what you need? Bill | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Donuts guys donuts! Being a retired Cop I’m an expert on donuts. What you guys are discussing is the block to header gasket. 52pu is talking the header pipe to exhaust pipe donut gasket. If I’m wrong I’ll gladly eat a donut.🤪
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm with you Martin.
......if my memory is correct I've seen some original exhaust header pipes with what appeared to be that tapered piece that the DONUT fit around. Surely ya'll have seen them???!!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If my memory serves me well: - the forward header is almost straight downward as in early 235 (and 216) exhaust manifold, and the end has a beveled opening (fitting surface) - donut gasket - the rearward header is more angled rearward as in 1954-1963 single 235/261 exhaust manifold, and has a flat opening (fitting surface) - flat gasket
If you have two different fittings on the two exhaust pipes, using the earlier donut seal/gasket in the front, and using the later 235/261 flat-gasket in the rear will work.
I have successfully used donut seals at both points, even with a flat rearward exhaust pipe.
What types of fittings are on the ends of your two exhaust manifolds, and on the mating sides of your two exhaust pipes?
| | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | I'm only talking about the Fenton to exhaust pipe connection, "donuts" we used to call them. Manf used to make them out of an asbestos mesh concoction, no more. The Walker PN 31524 is working so far. Also double nutting them is the way to go.
| | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | I had a '66 Buick and the exhaust manifold had the inverted bevel hole for the exhaust pipe just like the early 216s. It did not use a donut there. The exhaust pipe had a ball end formed onto it which fit into the beveled hole in the manifold. It had a flange similar to the 235 flange used to force the ball into place. As it was tightened, the ball end of the pipe form-fitted into the bevel. A good muffler shop should be able to form that ball end on your exhaust pipe.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Modern day Fenton headers sure aren't the same as the original castings. I drove my '60 6 cylinder Biscayne for 4 years and many miles back in the day. Got the header kit from the Sear catalog which included everything, hangers and all from the cylinder head right back to the tip of the tail pipes. Never ever had a problem with exhaust leaks. And the header castings fit perfect. I helped a friend install the (new) Fenton's on his 235 a couple of years ago and couldn't believe how poorly they fit. Flanges to the head didn't match up to the thickness of the intake and they just simply were not the same quality of the original headers. I believe the original ones had flat gaskets where the head pipe mated up to the header.....but that was '55 years ago and the memory.......well...... I can't remember what I had for supper last night. Denny G Sandwich, IL
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm with Denny. I remember the flat gasket Denny mentions...... DG....is there ANYTHING made today with the quality you and I grew up knowing?? You don't have to reply, I know the answer!...and it don't last near as long. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | It wasn't made in China back then Alvin. dg
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I think I said the same thing but my wording was kind of off key!! You are absolutely right. | | |
