5 members (Woogeroo, Wally / Montana, MickeyP, Lostbuthaulinass, 1 invisible), 120 guests, and 3 robots.
Topics128,050
Posts1,055,753
#1274086 07/28/2018 8:16 AM
I may be able to get hold of a 230 engine at reasonable cost and already here in the U.K. would this be a drop in replacement for the existing 216 engine. My truck is a 1953 3600 Chevy. I don’t want to have to start swapping out starter motors or Bell housing or welding engine mounts etc as it’s to difficult backward and forward to the states for parts. Or would I be better looking for a full pressure 235.
My 216 is running very well at the moment but I would like to try my hand at a engine rebuild. I have experience building Rover V8s and Landrover’s in the UK.
Chris
The 230 is a whole different engine, so mounts, bell housing, starter would all need to be changed out. Radiator might also need moved due to the low mount water pump on the 230. The 230 is a better engine by design, but the swap over would be difficult.
A 235 or a 261 would be a better choice for an upgrade. Both are virtually bolt-in swaps, depending on the year of manufacture of the larger engine. A 1954 or early-production 1955 235 or 261 would be the simplest to install. Late 55-62 engines need a little more tinkering, but they fit the existing bellhousing and motor mounts for the 216.
Many thanks that’s good information. I will stick with the 235 option.
Regards Chris
