1 members (klhansen),
70
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 28 New Guy | | New Guy Joined: Feb 2007 Posts: 28 | Has anyone used the product, ALL METAL body filler and if so did you like it?
Jim Elder Pembroke Pines Florida 64 GMC Stepside Grandaddies Truck Purchased New March 1964 AR Dyer Buick Hardinsburg Kentucky
| | | | | Joined: May 2007 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 36 | Yes it works great and a magnet will stick to it!If we are talking about the same thing. | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | Are you using it now? If so, how is it to work with? Does it set up quickly? Where did ya get it?
Boy, that's a lot of questions!!! | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Seems to set up about the same as Bondo, & it seems I need a skim coat of reg Bondo or finishing glaze to fill some imperfections-it is not as smooth as reg Bondo cause it has metal in it. My local FLAPS carries it, right next to the Dynalite & other brands of filler. | | | | | Joined: Jul 2005 Posts: 169 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 169 | Dont care for it one bit. IMO evercoat's rage or rage gold is far superior to all metal...Eric | | | | | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | When it comes to filling in small holes or over body seams All metal works good because it is not affected by moisture, which would cause polyester body filler to lift. As far as body filler goes I agree with Eric, evercoats rage is by far superior. Matt | | | | | Joined: Feb 2007 Posts: 28 New Guy | | New Guy Joined: Feb 2007 Posts: 28 | apreciate the responces, I have used all differing types of fill before, don't like running lead, was looking for something in a can that would be easier and seems like this is the item, and from what I have heard good for rust pin hole spot coverage after blasting
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I see no reason for a filler with metal in it unless the purpose is to thwart the magnet test if you're going to sell the vehicle. Most regular body fillers are a permanent, quality repair when used properly.
| | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | All Metal uses aluminum powder for the filler. It is not magnetic. It does not adsorb moisture. It is harder to work than other body fillers and can cost about twice as much. It's a good product for areas that may absorb moisture but does not compare to Evercoat Rage or Gold for workability and finish IMO. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | OK, I'm not familliar with the product. I was going by Truckman's post about a magnet sticking to it.
| | | | | Joined: Feb 2007 Posts: 28 New Guy | | New Guy Joined: Feb 2007 Posts: 28 | Thats why I wanted to use it, for those areas like lower cab cowls, corners and such. That was what I had heard about it. thanks
| | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | If you are looking for something like that, use a reinforced filler, like marglass made by several companys under different names, has sm strands of fiberglass and is water resistant. mixes like bondo. This is a great base for weak/pinhole areas to beef it up. use a regular filler over it to finish the area.
1970 C50 dump! saving orphans from the CRUSHER
