2 members (carbking, RLB), 157 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#127389 07/18/2007 11:20 PM
Has anyone used the product, ALL METAL body filler and if so did you like it?
Jim Elder Pembroke Pines Florida
64 GMC Stepside
Grandaddies Truck
Purchased New
March 1964
AR Dyer Buick
Hardinsburg Kentucky
#127390 07/19/2007 1:56 AM
Yes it works great and a magnet will stick to it!If we are talking about the same thing.
1955 GMC Big Window
1957 Chevy 1.5-Ton
1959 Chevy Short Fleetside
Plus lots more ...I LOVE THESE TRUCKS!!!
#127391 07/20/2007 11:18 AM
Are you using it now? If so, how is it to work with? Does it set up quickly? Where did ya get it?
Boy, that's a lot of questions!!!
#127392 07/20/2007 1:46 PM
Seems to set up about the same as Bondo, & it seems I need a skim coat of reg Bondo or finishing glaze to fill some imperfections-it is not as smooth as reg Bondo cause it has metal in it. My local FLAPS carries it, right next to the Dynalite & other brands of filler.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#127393 07/20/2007 7:45 PM
Dont care for it one bit. IMO evercoat's rage or rage gold is far superior to all metal...Eric
Currently working on custom metal and How to videos.
1949 and 1972 chevy trucks
70 chevelle SS455
Pictures of my work and projects
http://community.webshots.com/user/sevt_chevelle
#127394 07/21/2007 1:39 AM
When it comes to filling in small holes or over body seams All metal works good because it is not affected by moisture, which would cause polyester body filler to lift. As far as body filler goes I agree with Eric, evercoats rage is by far superior. Matt
#127395 07/21/2007 11:21 PM
apreciate the responces, I have used all differing types of fill before, don't like running lead, was looking for something in a can that would be easier and seems like this is the item, and from what I have heard good for rust pin hole spot coverage after blasting
64 GMC Stepside
Grandaddies Truck
Purchased New
March 1964
AR Dyer Buick
#127396 07/22/2007 12:27 AM
Ex Hall Monitor
Ex Hall Monitor
I see no reason for a filler with metal in it unless the purpose is to thwart the magnet test if you're going to sell the vehicle. Most regular body fillers are a permanent, quality repair when used properly.
#127397 07/22/2007 5:36 PM
All Metal uses aluminum powder for the filler. It is not magnetic. It does not adsorb moisture.
It is harder to work than other body fillers and can cost about twice as much.
It's a good product for areas that may absorb moisture but does not compare to Evercoat Rage or Gold for workability and finish IMO.
#127398 07/22/2007 6:01 PM
Ex Hall Monitor
Ex Hall Monitor
OK, I'm not familliar with the product. I was going by Truckman's post about a magnet sticking to it.
#127399 07/24/2007 12:12 AM
Thats why I wanted to use it, for those areas like lower cab cowls, corners and such. That was what I had heard about it. thanks
64 GMC Stepside
Grandaddies Truck
Purchased New
March 1964
AR Dyer Buick
#127400 07/27/2007 12:35 AM
If you are looking for something like that, use a reinforced filler, like marglass made by several companys under different names, has sm strands of fiberglass and is water resistant. mixes like bondo. This is a great base for weak/pinhole areas to beef it up. use a regular filler over it to finish the area.
1970 C50 dump! saving orphans from the CRUSHER
