Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#1273458 07/23/2018 4:08 AM
Fox
Offline
As I’ve become more “educated” in things automotive, I like the nicknames that have popped up over time in regards to vehicle engines.
What are your favourite names assigned to engines?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Fox #1273480 07/23/2018 11:52 AM
Read something John called a Detroit a green leaker or something like that lots of nicknames for Detroit desiels
Fox #1273496 07/23/2018 12:46 PM
"Nailhead" , "Drophead", "Monster", "Rat", "Mouse", "Elephant" are a few of my favorites.
Fox #1273541 07/23/2018 6:22 PM
Insomniac
Insomniac
knucklehead
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Fox #1273542 07/23/2018 6:24 PM
Flat Head, Pan Head, Shovel Head.
Brian
1955.2 3100 Truck
Fox #1273544 07/23/2018 6:52 PM
Son of a [censored]!
Fox #1273558 07/23/2018 8:58 PM
For some reason, I have always liked Stovebolt Six
Stove Bolt Six - The Cast Iron Wonder
Fox #1273565 07/23/2018 9:46 PM
Drophead is an English chassis/body term for 2 door convertible.
Fox #1273582 07/24/2018 1:46 AM
H Online: Content
This is a family-friendly forum- - - - - -I can't repeat the names I've had for some of the ones I've owned and/or worked on! Let it suffice to say there were lots of dogs, frogs, and other critters in their ancestry!
Fox #1273597 07/24/2018 3:15 AM
A good ol mechanical four and a quarter with a thirteen over in a corn binder.
J. F.
Fox #1273599 07/24/2018 3:51 AM
Fox
Offline
It seems I have lots of reading and learning left to do!
Santerre,
Are you referring to Internationals?
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox #1273603 07/24/2018 4:06 AM
H Online: Content
That Binder works better with a 5 X 4 instead of a 13 over!
Fox #1273606 07/24/2018 5:03 AM
It is fairly flat around here.... We'll keep the extra gear for the screaming Jimmy and ther narrow power band...
J. F.
Fox #1273614 07/24/2018 11:17 AM
Johnny Popper (John Deere 2 cylinder tractor engines), very distinct sound.
Rick
1939 Chevrolet Stake Truck
Fox #1273622 07/24/2018 12:48 PM
V
V Offline
Hit and Miss...
Rice burner
May-popsie
Iron Duke
Seven Little
Fox #1274087 07/28/2018 8:20 AM
I’m really not sure we do engine naming in the U.K. apart from “xxxx won’t start “ . At the moment Stovebolt is my favourite.
Regards Chris
Fox #1274092 07/28/2018 10:03 AM
single cylinder engines (Briggs/Tecumsehs) as "One Lung-ers"
Fox #1274126 07/28/2018 3:06 PM
The Inliners club (http://inlinersinternational.org/) call a V8 a "parallel four".
;-) Dean
Dean 'Rustoholic' Meltz
Lurch: 1927 1-Ton Chevy Cattle Truck
Old and ugly is beautiful! -- The Saga
Lurch's Gallery
Justin: 1928 Chevrolet AB Canopy Express
Fox #1281023 09/21/2018 8:44 AM
well here in oz donk is often used to describe an engine
1934 1-1/2 ton truck (Australia)
Fox #1281035 09/21/2018 1:05 PM
I live about an hour of Atlanta, GA. Here a donk is a creation that has wheels and tires taken to extremes.
Donk
Usually they are GM G bodies with 26 inch wheels with a crazy paint job and interior. Just like the low rider crowd in Southern California.
SimS
Fox #1281070 09/21/2018 7:07 PM
Leo Offline
Moderator
Moderator
never had these but slant six, wedge and hemi. Then there are 4 bangers and six bangers.
Fox #1281270 09/23/2018 9:53 PM
4 cylinders are called 4 bangers or just bangers for short.
Professional Novice
Fox #1281290 09/24/2018 2:00 AM
Pontiac of Canada used the 261 motor as their base motor. The valve cover was the same as a Chevy valve cover but without the script. Pontiac called these motors the Strato-six. I always liked that name.
Mike
Fox #1281322 09/24/2018 12:38 PM
Strato-Six - nice name & nice information. - thanks
Unlike the USA 261, those Canadian Pontiac/car 261s had hydraulic lifters.
The Canadian truck 261s had mechanical lifters (as used in USA truck 261s).
Fox #1281333 09/24/2018 2:20 PM
Bond Villain
Bond Villain
Do the big block Fords have a name? I've heard them called "Windsors" but I thought those were the smaller blocks... What's a "Cleveland" then?
Tim -- There's a whole lingo for Detroit Diesels .... Green Leakers, Driptroits, Rocky Mountain Humming Birds, Green Screamers ... just a few that come to mind. I miss that ole 6-71. It was a fun engine to drive around on top of ... smile Drove one the other day hooked to a 9-speed RR. Every gear sounded like the Apocalypse ... smile (Note: I've never actually heard an Apocalypse, I'm just using it as a simile ... in case you were wondering ... smile )
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Fox #1281341 09/24/2018 3:00 PM
H Online: Content
Furd big blocks have several names, other than "First On Race Day". The old 332/352/390/406/427 engines are called "F.E." engines by Ford guys. Then there's the whole series of 351's- - - -the Windsor is a raised block version of the 260/289/302 line, with a one inch taller deck height to accommodate a longer stroke crankshaft. 351W cylinder heads will bolt onto a 302. The only difference is the fact that 351's use 1/2" diameter head bolts instead of 7/16". Then there's the "351 Cleveland", a bigger block engine with much more efficient cylinder heads than the Windsor. There's also a downsized version of the 400 cubic inch big block called a 351M (modified). The really big-inch Ford engines are the 460's which have a block casting all their own. In some situations back in the late 1970's when the tree huggers were in full panic mode and the EPA was changing their rules on a monthly basis, it was necessary to know where a Ford engine was manufactured in order to get the right tune-up specifications for emission control purposes.
Windsor and Cleveland were used to designate the two 351 CU In engines in production at the same time. You had the FE engines, and the 429-460 big block but I don't recall any cool nick names for them
Chuck
Fox #1281343 09/24/2018 3:10 PM
H Online: Content
Hmmmmm- - - -forgot about the 429! The engineering department at Chrysler had an anagram for the V-10 Viper engine while it was under development- - - - -"B.F.M."! No translation necessary!
Fox #1281347 09/24/2018 3:48 PM
Ex Hall Monitor
Ex Hall Monitor
The 351 Windsor was made in Windsor Ontario, the Cleveland 351 was made in Cleveland OH.
Fox #1281350 09/24/2018 4:01 PM
How about the old Buick “Straight Eight”. Not a name as much as a description but still cool.
Saw a couple of them yesterday at a car show.
Fox #1281353 09/24/2018 4:12 PM
H Online: Content
Nash, Studebaker, Packard, Chrysler, Oldsmobile, Pontiac, and a few others all used straight 8 engines. It was a logical upgrade from a six in terms of power and smoothness in a higher-priced vehicle than the Chevy/Dodge/Plymouth car lines. Ford used V8's instead of sixes, other than a very limited production run of flathead sixes from 1941-51.
Fox #1281369 09/24/2018 7:07 PM
The GMC 702 V12 was called "Twin Six"
1952 Chevrolet 3800 pickup
---All pictures---
Fox #1281385 09/24/2018 10:45 PM
V
V Offline
I had a HiPo 390 FE in a 67 Mercury Cyclone GT. That baby would run.....
Fox #1281391 09/24/2018 11:12 PM
390 Thunderbird Police Interceptor (package) on my mother's 1964 Ford Custom (it later became the 427/428 Police Interceptor).
Fox #1281392 09/24/2018 11:15 PM
My 1957 Ford Fairlane (my first vehicle) had a 312 V8 with Thunderbird stamped on the valve covers.
Rick
Fox #1281394 09/24/2018 11:25 PM
The Buick straight 8 was called the Fireball Eight.
Chrysler Red Ram
Fox #1281403 09/24/2018 11:59 PM
I saw the reference to Chrysler's slant six and can't help but add the Super Six, same slanted 225 with a 2 barrel carb instead of the single.. had one of those and man it wouldn't die, even when abused in a field car for 2 years using pond water coolant (which did freeze bending but not popping the frost plug) and just enough oil to show on the dipstick
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
