8 members (Otto Skorzeny, Bill Marlow, HandyAndy, GRNHydra, 49nut, Wally / Montana, cmayna, 1 invisible),
256
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,980 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 57 'Bolter | | 'Bolter Joined: Mar 2015 Posts: 57 | 51 3100 stock springs changed rear end to Camaro rearend now back of truck looks raised can i take 3 of the 7 leafs out to not only lower it a little plus give the truck a smother ride dont really want to add lowering blocks brtween axel and springs | | | | | Joined: Feb 2000 Posts: 5,210 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,210 | You won't lower it much, 1/2" to 3/4 or so. If you remove leaves, leave the two longest and take every other one, as told to me by a local spring shop. If you do this, the weight capacity will cut drastically. Try add teflon liners to the spring pack after cleaning each leaf. You will need to disassemble them, but they should have a good going through anyway. I have used this stuff with good results, https://www.speedwaymotors.com/Leaf-Spring-Liner-with-Lip-1-3-4-Inch,2079.html , it will help. | | | | | Joined: Feb 2017 Posts: 83 Vintage Truck & Tractor | | Vintage Truck & Tractor Joined: Feb 2017 Posts: 83 | I did that on a 51 Ford F3. I started at the bottom and worked my way up. I removed the second, fourth & sixth leaf.. made a profound differance in ride. Lowered it too.. Also better off buying new spring U bolts. Dont waste your yr time with rusty old ones.
Current project; 1961 C20, 235 I6
