0 members (), 66 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#1272236 07/12/2018 2:13 PM
A little help please. Does anyone have a good alternate method of attaching the beaded window seal to the window trim piece? Trying to use staples is nearly impossible. Or at least extremely frustrating.
Insomniac
Insomniac
I used adhesive instead of staples. Simply following a suggestion made by others on this forum.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I would like to have seen the procedure for installing the staples from back then.
3M Black Weatherstrip Adhesive works perfect.....on the window seals, on the windlace rubber, on the door weatherstrip. Make sure it is correct the first time though.
Mike
1951 3100 5 window
I used #3 screws on mine.
Jhyp #1272401 07/14/2018 12:00 AM
I used BOTH....using the tiny screws like at the end and maybe one in the middle..and the adhesive. Maybe I just like a little overkill. lol
3M weatherstrip adhesive,,,,,,,, been holding for 24 years now.
