| | | Forums66 Topics128,281 Posts1,058,465 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 182 'Bolter | | 'Bolter Joined: Jun 2016 Posts: 182 | A little help please. Does anyone have a good alternate method of attaching the beaded window seal to the window trim piece? Trying to use staples is nearly impossible. Or at least extremely frustrating. | | | | | Joined: Jul 2000 Posts: 2,213 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,213 | I used adhesive instead of staples. Simply following a suggestion made by others on this forum.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Mar 2016 Posts: 226 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 226 | I would like to have seen the procedure for installing the staples from back then.
3M Black Weatherstrip Adhesive works perfect.....on the window seals, on the windlace rubber, on the door weatherstrip. Make sure it is correct the first time though.
Mike
1951 3100 5 window
| | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | I used #3 screws on mine. | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | I used BOTH....using the tiny screws like at the end and maybe one in the middle..and the adhesive. Maybe I just like a little overkill. lol | | | | | Joined: Nov 2001 Posts: 1,523 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,523 | 3M weatherstrip adhesive,,,,,,,, been holding for 24 years now. | | |
