| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | I'm reassembling my front end and have all the tin together, just having a slight issue with the core support harware where it bolts to the fwd. cross member. The mess of parts I took out was in sad shape and all of the leather/rubber/cardboard I took out was useless to me so I need to find a source for replacements or make something myself. The main question I have is on the U-bolt, there are two springs and I want to make sure I place them correctly. Do they go in between the core support and the x-member, or under the X-member? Thanks! 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | Sounds like you need a factory assembly manual. $30.00 all over Ebay or from any of the part suppliers. It should anser this and many other questions. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I see ya got a GMC - might be retro, using the pre 55 setup - no U bolt in Chev TF rad mount hardware, nor a spring for that matter - for the Chevy TF years, there's mount pockets at the bottom of the core support, and the bolt goes thru those and some fat washers into the brackets that are riveted to the frame rails [not crossmember], and yes, an assembly manual is helpful, but I think there's not one for the GMC? here's a pic of the Chevy core support , I think you need to be looking for GMC specific info .... American Classic lists GMC specific rad mount pads, like this Bill | | |
