9 members (TUTS 59, Millenimech, cmayna, Hanks custodian, Otto Skorzeny, Oswald, Cosmo, Bill Hanlon, gswbbc), 89 guests, and 3 robots.
Topics128,042
Posts1,055,522
Members48,424
#1271991 07/10/2018 2:54 PM
I found a 1948 2 ton parts truck. It has the 5 window cab and even the original radio in it! What I'm curious about is that the shifter has a button/switch on it like a hi/lo but the hi/lo switch is in the dash. What else could it be?
2 speed rear axle.🛠
Is the 2 speed rear end vacuum or electric shift? It's possible the rear end has been upgraded to electric, and the dash button for the vacuum shift axle was not removed.
I'll have to look at it again. It looked like the diff shifter still had the vacuum lines connected. Did the SM420 ever have a reverse lockout?
Or possibly an overdrive?
IF you have a SM420, the answer to both your posts above is...NO.
Is the gear shift knob red and it can be pulled up and down or is it a flip lever connected to a metal rod going down to the transmission?
Pictures would help.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
It's a flip lever with a rod. Sorry, I didn't remember to take pictures when I saw it. I'll have some posted up soon.
Thanks for the help though!
Sounds like a reverse lock out.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Probably a dumb question but are you sure the hi-low switch is in the dash? Would make more sense for the dash switch to be pto or something else.
Stuff I’m gonna work on, I swear
1963 C30 flatbed
1961 Apache 30 (parts, no title)
1960 GMC Big Bolt
Don't tweet, face, Google, or link. Just hanging in as long as I can...
3B Offline
Hy Fitzy440 and guys, it sounds like you are describing the reverse lockout lever that was on the sliding gear transmissions, those transmissions were used up to the 1947 model year, are you sure this truck is actually a 1948 model?
That is what the owner said. The truck is partially covered in a junk pile so I haven't been able to get to the serial number. We are going to go back up this weekend and try to uncover it and get some pictures. Like I said, it is a parts truck. Not the best looking.
I agree with 3B...sounds like the old Crash Box transmission with the lock out switch.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Crusing in the Passing Lane
Looks nice.
Ed
Could be a 47.
In any case it's lockout for reverse on the older model transmission
1952 Chevrolet 3800 pickup
---All pictures---
