4 members (TUTS 59, PAUL Berardi, 68ironhead, Peggy M), 120 guests, and 1 robot.
Topics128,130
Posts1,056,369
Members48,441
#1270956 07/02/2018 5:09 PM
Hello all, looking for suggestions or information on what everyone is doing to cap their vacuum port on the manifold
I am using a double action fuel pump, so I do not need this for wipers
I would like to still have access to the port for tuning with vacuum gauge
I would think a ball valve and barbed fitting with vinyl cap, but that may look clunky
1949 Chevrolet 3100 Suburban Carryall
"Bad Guy"
More pix in Photobucket
1950 Chevrolet 3100 3-Window
More pix on Photobucket
1966 GMC Suburban Carryall Custom
"Big Guy"
What's wrong with what you're doing now? It looks simple and effective.
Riding in the Passing Lane
The double fuel pump is an aux. vacuum source. You still should use the manifold vacuum for wipers.
George
1972 Chevy c10 Cheyenne Super
This may give you an idea...
Lots more pictures
George
George is describing the GM/factory way. Other plumbing patterns could/should work.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0673.htm
Thanks Paul
That’s exactly what I was thinking
Is that ball valve 1/8” npt?
"Bad Guy"
"Big Guy"
Thanks Paul
Yes it is a 1/8" NPT ball valve that I picked up at my local auto parts place.
Lots more pictures
The vacuum pump delivers a smaller vacuum than the manifold. It is meant to augment the vacuum when it is low in the manifold. The pump will not deliver a lot of vacuum at low RPMs. At least, that is how GM explains it. I think when I had mine it would deliver about 11" at a higher RPM.
1951 1 Ton Completed
