| | | Forums66 Topics128,185 Posts1,057,281 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2018 Posts: 93 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 93 | I broke this trying to blindly feel my way around and remove this from the dash. Is this repairable somehow or do I need to start shopping for a new one? It appears that it just pressed in but I have yet to disassemble the gauge cluster to to look inside. Busted Ammeter Gauge Terminalfyi- I am also switching to 12v from the current stock 6v system if that skews the answer in any way.
Jason Working on my first restomod on a 1950 3100 Shortbed (235 engine, 3 on the tree, disc brakes, etc.) 1950 Chevy 3100 | | | | | Joined: Jul 2004 Posts: 2,995 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,995 | The 12 volt part won't affect it at all. Not sure whether that can be repaired or not. Someone will know. | | | | | Joined: Feb 2004 Posts: 29,880 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,880 | Unfortunately, that ammeter is beyond repair. That stud is pressed into a shunt that is very sensitive to resistance in the connection. You'll hear a lot of advice in about 3- - -2- - - -1 seconds that using an ammeter on 12 volts will cause something akin to the Chicago fire. I print those comments out and use them to fertilize my garden. Find yourself another ammeter, and rig a second shunt to bypass some of the charging current around the meter movement to keep it from pegging out for the first few seconds after startup. Drop me a PM and I'll describe how to do that. Jerry
