3 members (Steveoreno, moparguy, carbking), 58 guests, and 5 robots.
Topics128,179
Posts1,057,162
Members48,465
I broke this trying to blindly feel my way around and remove this from the dash. Is this repairable somehow or do I need to start shopping for a new one? It appears that it just pressed in but I have yet to disassemble the gauge cluster to to look inside.
Busted Ammeter Gauge Terminal
fyi- I am also switching to 12v from the current stock 6v system if that skews the answer in any way.
Jason
Working on my first restomod on a 1950 3100 Shortbed (235 engine, 3 on the tree, disc brakes, etc.)
1950 Chevy 3100
The 12 volt part won't affect it at all.
Not sure whether that can be repaired or not. Someone will know.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Unfortunately, that ammeter is beyond repair. That stud is pressed into a shunt that is very sensitive to resistance in the connection. You'll hear a lot of advice in about 3- - -2- - - -1 seconds that using an ammeter on 12 volts will cause something akin to the Chicago fire. I print those comments out and use them to fertilize my garden. Find yourself another ammeter, and rig a second shunt to bypass some of the charging current around the meter movement to keep it from pegging out for the first few seconds after startup. Drop me a PM and I'll describe how to do that.
