3 members (DES57, 2-Ton, 1 invisible), 102 guests, and 2 robots.
Topics128,211
Posts1,057,469
Members48,473
I love I6 my 54 has appropriate motor
I bought a 1950 parts truck and decided to bring it back from the dead.
I thought it had a 1950 216 but it turns out to be 1953 truck or manual tranny car motor. Kind of a one off engine w/ 54 and later head but the 2 nut valve cover rather than the 4 bolts on the side
Pulled valve cover and side cover (like 54 235 not like 216) , it was used but not to funky;
Next came the head, no rust and a ridge that could probably honed out...
I am not going to rebuild this one as I have 2 power glide 235s.
Should it go to scrap yard or should I shove it in the corner?
How many of you guys have spare engines sitting around?
1954 Std Cab 3100 w/ 2 spare Engines
IL
1954 three window 3100
That's a fairly scarce engine, worth something to someone who is doing a correct-engine truck restoration. I's keep it and maybe run an ad on Craigslist- - - -no telling what kind of pocket change it might bring from the right buyer.
First off I will admit that I have a few "spare" engines tucked into corners, so my advice may just be enabling bad behavior. I agree with Jerry though on keeping the engine. Yes it is a babbit engine that not too many folks are overly concerned with these days, but it sounds like it is a complete operable engine. Getting rarer every day. If you have the space, I would advise to keep the engine as perhaps someone in the future may need some scarce parts.
Lots more pictures
Crusing in the Passing Lane
I will have to admit to having a few 'spare' 302's, Detroits, 503's, 5 and 6 speed trans', 22.5 wheels around, one can never tell if I or others may need something. Once the scrap man gets them, all is lost.
Ed
The head is at least worth keeping.
Although it is not drilled for the four bolt cover, it will fit 1954-62 engines.
My Blog
Thanks all for response. I knew it was an oddball engine; didn't think about the rarity - good point.
I guess it is a good thing that I am taking things apart properly so I know which hole the lifters and push rods go back into (although I would guess they would all be replaced). I probably clean it up, oil it up and shove it back into a corner,
IL
