| | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 87 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 87 | I love I6 my 54 has appropriate motor
I bought a 1950 parts truck and decided to bring it back from the dead.
I thought it had a 1950 216 but it turns out to be 1953 truck or manual tranny car motor. Kind of a one off engine w/ 54 and later head but the 2 nut valve cover rather than the 4 bolts on the side
Pulled valve cover and side cover (like 54 235 not like 216) , it was used but not to funky;
Next came the head, no rust and a ridge that could probably honed out...
I am not going to rebuild this one as I have 2 power glide 235s.
Should it go to scrap yard or should I shove it in the corner?
How many of you guys have spare engines sitting around? | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | That's a fairly scarce engine, worth something to someone who is doing a correct-engine truck restoration. I's keep it and maybe run an ad on Craigslist- - - -no telling what kind of pocket change it might bring from the right buyer. Jerry
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | First off I will admit that I have a few "spare" engines tucked into corners, so my advice may just be enabling bad behavior. I agree with Jerry though on keeping the engine. Yes it is a babbit engine that not too many folks are overly concerned with these days, but it sounds like it is a complete operable engine. Getting rarer every day. If you have the space, I would advise to keep the engine as perhaps someone in the future may need some scarce parts. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I will have to admit to having a few 'spare' 302's, Detroits, 503's, 5 and 6 speed trans', 22.5 wheels around, one can never tell if I or others may need something. Once the scrap man gets them, all is lost.
Ed
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The head is at least worth keeping. Although it is not drilled for the four bolt cover, it will fit 1954-62 engines.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2017 Posts: 87 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 87 | Thanks all for response. I knew it was an oddball engine; didn't think about the rarity - good point.
I guess it is a good thing that I am taking things apart properly so I know which hole the lifters and push rods go back into (although I would guess they would all be replaced). I probably clean it up, oil it up and shove it back into a corner, | | |
