Here is the air flow heater (non-recalculating model)
Installation instructions Pages 36 to 39(2) The air flow only non-recirculating heater has a cable control, that opens or closes a door, for defrost or floor heat .
(3) The air flow / recirculating heater has a cable control, that opens or closes doors, to recirculate cabin air or bring in and heat outside air. (keeps windows from fogging up. The defrost to floor air control was done manually using a lever located on the heater box.
There were really three heaters that were widely used in Advance Design Trucks.
(1) Recirculating (only) round type heater 1947-55 1st series (round heater core) defrost to floor air control was done manually using a lever located on the heater box.
(2) 1947-52 Air flow non-recirculating (no doors) (rectangular heater core)
Picture of heaters 1 & 2 (Another quality photo from Brad Allen)
(3) 1953-55 1st series Air Flow / Recirculating (with doors) (rectangular heater core, same as # 2)
Picture of heater # 3 (Another quality photo from Brad Allen) x2
There were different speed switches for controlling fan speeds used on the heaters.
Wiring is fairly simple.
There was a temperature control valve used on heaters 2 & 3
