4 members (Oswald, treegrower, Nick in Manitou, 1 invisible), 40 guests, and 3 robots.
Topics128,076
Posts1,055,920
Members48,429
My parts place sells a set of kingpins in normal size and a set that is .10 over. How do I know which to order?
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
By measuring the kingpin holes in the axle beam, should be a snug push fit on the kingpin when clean, only a couple tenthousandths of an inch over pin diameter.
If the holes are worn egg shaped then the oversized kingpin kit is the repair, along with accurately reaming the axle beam to fit the oversized pins.
Actually 0.010” oversize.
1952 Chevrolet 3800 pickup
---All pictures---
How does your old pin fit the axle bore? If the axle bore is no longer round, you need to ream it out to fit oversized pins. If the bore is still round with a good tight fit of the original pins, then order the standard size.
The spindle bushings will match the pins, but if the spindle bores are worn, they will need repaired or replaced. Oversize pins are not for spindle repair, they are to correct axle bore problems.
The over-size king pin sets are for situations where the king pin holes in the axle are loose/worn - that problem is sometimes solved by drilling/reaming over-sized holes in the axle.
Thanks for help fellas. At this point I think I'm putting the cart before the horse. I guess I need to pull it off and check for egg shaped axle holes before I order.
To say it another way...
Wait, its already been said the same way 3 times. smile smile smile
Thanks everyone!
